跳转到主内容
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
369 个问题 查看全部
Accidentally disabled OEM unlock on rooted phone
I accidentally disabled the OEM unlock option on my rooted S7, and am now stuck in bootloop. I can get into download mode but not recovery mode.
I have tried to flash a stock firmware, however odin stops at this point:
<ID:0/007> Added!!
<ID:0/007> Odin engine v(ID:3.1301)..
<ID:0/007> File analysis..
<ID:0/007> Total Binary size: 4089 M
<ID:0/007> SetupConnection..
<ID:0/007> Initialzation..
<ID:0/007> Get PIT for mapping..
<ID:0/007> Firmware update start..
<ID:0/007> NAND Write Start!!
<ID:0/007> SingleDownload.
<ID:0/007> boot.img
<ID:0/007> recovery.img
<ID:0/007> system.img
<ID:0/007> FAIL!
<ID:0/007>
<ID:0/007> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
Is it possible for me to fix my phone, or do I need to buy a new one? if it is possible for me to fix it, how?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
You see the message custom binary blocked by FRP lock on the top left of the screen with the Samsung white text in the middle right?
Now there are only two ways to fix this and one involves factory resetting the phone.
You'll need to reflash stock firmware preferably the latest one via ODIN.
Once that's done you'll need to wipe data in recovery mode which means data will lost if it's stuck on Samsung logo, otherwise there'll be a button to press after boot to wipe data on phone.
Here is a guide on how to flash Samsung firmware if needed:
http://updato.com/how-to/how-to-install-...
If you have a GSM flashing box by any chance such as Z3X you can use the reset FRP/UFS option without needing to wipe data.
这个答案有帮助吗?
得分 0
2条评论:
are you able to help with my error when trying this?
完成的
Make sure you are using Odin v3.13 or newer because it's required to flash 8.0.0 / Oreo firmware. If flashing firmware older than what's already on there it may not flash as well.
完成的
添加一条评论
添加你的答案
Luke Hoskins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 2,031
