跳转到主内容
Whirlpool Quiet Partner III won't drain
I just reinstalled my dishwasher after it had been stored for a few years in my unheated garage.  The water inlet valve was cracked (big surprise) so I replaced it.  Now when I ran a test cycle, the water is not draining from the dishwasher.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
HI:
Could be your drain pump is bad. But sitting for a year also the filter, grinder and area could be full of debris. Here is a great site to give you ideas on how to fix your washer, As you look for a part and click on the part picture you get a video on how to replace this part, but then you can see how the unit is put together and clean your unit out. Or replace parts not working. I am guessing a stuck flap valve also could be stuck closed.
https://www.partselect.ca/Models/GU1100X...
Good luck.
Alton
Pumps water out of your dishwasher during the drain cycle.图片
产品
Whirlpool Dishwasher Drain Pump - WP661658
$61.99
这个答案有帮助吗?
得分 1
1条评论:
Turns out the drain pump motor was bad.  Cleaned up the filter, grinder and flap valve.  So far, so good.  Thanks!
完成的
添加一条评论
添加你的答案
Lee Best 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 2,351
