Bluetooth connected but no sound. faulty charger
My SuperLife Jacket has bluetooth connection but no sound. Second time this happens after exchanged it. Also faulty power connector wont charge battery
I have the same charging issue… I found that the prong inside the DC in port BARELY comes in contact with the two contacts from the charger… i bent the contacts toward the center to ensure they touch the prong inside the port… It seems to work for a while… then i have to do it again… and again… Recently i haven’t had to do it… it… just works now…
这个答案有帮助吗?
To fix it Replace the pcm1808 chip on the main board this will restore sound. Hours of troubleshooting so you're welcome
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 899
