跳转到主内容
An Android digital 9'' tablet, made by APEX.
What should I do if the motherboard capacitor is broken?
When I opened the case to clean the dust today, I found two capacitors violent, (it reads fz57 150 6.3V)
Excuse me, what should I do? ? ?
What effect does the two capacitors have on the computer? ?
(Currently everything is normal, in use)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Not knowing where these fit in the scheme of things, I can guess that these are likely filter capacitors that eliminate noise on the DC supply line. If this is the case, then replacing them is recommended as these will help to protect hte CPU as well as prevent the “logical maybe” which occurs when the voltage fluctuates. These are most likely surface mounted devices which require a bit of experience to replace. Get them replaced.
Dan
这个答案有帮助吗?
得分 1
1条评论:
thank you for your help,i will try it.
完成的
添加一条评论
添加你的答案
Annaa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 183
