跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
Need to upgrade OS
Hi.
My Mac pro (2.4 GHz intel core duo) is running 10.6.8 and I am increasingly having trouble with using online banking and using programs that need a newer OS.
I am not a techie person so can you explain how I can upgrade?
All the upgrades I’ve downloaded don’t work. 10.6.8 update says “installer can’t locate the data it needs to install” and other installers that claim to be able to upgrade from my version say “I need 10.7 to install”.
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sadly, you need to get to Mountain Lion 10.8 to then upgrade off of the App Store. Heres what you’ll need to buy OS-X Mountain Lion 10.8.x as its on CD.
这个答案有帮助吗?
得分 0
1条评论:
I will try that. thank you!
完成的
添加一条评论
I think this article should be able to help you out. Basically you can do the updates/upgrade right through the App Store. Be sure to back up any important files you need prior to upgrading, just in case.
https://support.apple.com/en-us/HT201541
这个答案有帮助吗?
得分 0
1条评论:
Only once you have the required base OS, Lion or Mountain Lion
完成的
添加一条评论
添加你的答案
makeupwithdani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 75
