跳转到主内容
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
What is rattling in my controller?
My son dropped his xbox one Wireless controller and now it makes a rattling sound when it is shaken. What is causing the rattle? Did a small plastic piece break loose inside the controller? Any information will be greatly appreciated… Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
As @zantheproplayz said, it could be a broken stud, but it is also possible it is damage to one of the haptic motors. Chances are it’s harmless, and these controllers are quite easy to get apart as well.
Good luck!
EDIT: Follow this guide and once you get the faceplate off, shake it around a bit, and see if anything comes out. That will stop the rattling if it is in fact a broken plastic piece.
这个答案有帮助吗?
得分 2
2条评论:
This did not work for me. the rattle in my elite v2 controller is not coming from any broken part. The rattle only happens when the motors spin fast, i think they are loose. I have as of yet to come up with a solution as there seems to be no good teardown of the v2 elite controller, so im not sure how to take it apart. Im going to give it a try and assuming i get it back together, ill make a guide on it.
完成的
So if my left bumper above the trigger feels loose do I have to worry about it?
完成的
添加一条评论
最有帮助的答案
Hi!
I have this problem once and if the controller is working, nothing to worry about. its just a piece of plastic or a piece of a stud broken off lose and mke the rattling noise.
Hope this Helps
这个答案有帮助吗?
得分 4
添加一条评论
I reccomend removing that batteries inside and continuously shake it, while upside down, to remove the loose piece
这个答案有帮助吗?
得分 2
3条评论:
Tysm!
完成的
This worked for me, thanks!
完成的
It gets stuck between the circuits
完成的
添加一条评论
Let me try first and tysm
这个答案有帮助吗?
得分 0
1条评论:
No I tried that multiple times and it keeps getting stuck between the circuits
完成的
添加一条评论
添加你的答案
Dustin Baker 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 46
过去 30 天: 181
总计 32,063
