跳转到主内容
加入维修社区 - 创建账户
Also known as a multitester, or a VOM (Volt-Ohm meter), a multimeter is an electronic measuring instrument used to measure voltage, current, and resistance. Includes handheld and tabletop testing devices.
Multie Meter Not Doing Continuity
Hi,
My Digitech Multie Meter douse not do continuity.
I first noticed this when I went to use it this morning.
All I hear is just a long beep
Here is a photo
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What happens when you try to unplug both probes? Does it still have the same issue?
If this is the case it’s probably the issue with the multimeter board and buying another one will be the better option as it’s not worth spending time and money on trying to get that one fixed.
I recommend Fluke meters as they are rugged, reliable and accurate.
这个答案有帮助吗?
得分 1
1条评论:
Hi,
Thankyou I think I will buy a new one as you suggested
完成的
添加一条评论
添加你的答案
Robbie1155 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 1,450
