跳转到主内容
这是iPad mini 3(型号A1599)Wi-Fi版本的维修指南。这款iPad在2014年10月6号作为iPad Mini Retina屏版本(现在也做iPad mini 2)的新一代被发布。
Home Button Failure after Display Assembly Replacement
After a successful replacement of the glass on an iPad mini 3, the undamaged home button is not functioning when pressed. There are no errors reported on start-up. Given these circumstances, does this mean the connector on the logic board has been damaged? Again there are no signs of damage that I can detect.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Assuming you don’t have a teeny microtear in the flex then the MOST LIKELY problem is a parts problem on the screen. These are notoriously bad. Definitely make sure to test home button function before sealing it up.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 84
