跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
home button ring is raised from top
hey guys I have bought a 7 plus yesterday and what I have noticed is that the ring on the home button is a little bit raised or sticking out on top and perfectly aligned on other sides, it works fine though the touch, the taptic engine. I have a 7 also but it is fine, also the sim tray is not original it doesn’t have a seal on it. the main concern is TOUCH ID. Should i return the phone and get other one or is it okay and I continue using it. will it get damaged or failed?
its so much minor that I could only feel it by swiping my finger over it and by looking very closely to surface I can see it a bit raised on top …
Please describe the best solution
Thanks in Advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
I think it should be fine. Maybe its a refurbished unit from a local shop and the screen had been replaced.
这个答案有帮助吗?
得分 0
添加一条评论
This sounds like a privately refurbished phone, do not consider it be new or waterproof or perfectly repaired.
If you bought it for cheap “as is”, I guess it’s OK. If you bought it as “new” or “almost new”, talk to the seller.
这个答案有帮助吗?
得分 0
添加一条评论
I would honestly just re-seat the home button as it is possible to get a pressure crack and loose certain functions. If the phone was refurbished and the screen was replaced, there may not have been enough attention to detail when seating the home button.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sania Nadeem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 434
