跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Why is my bluetooth range so poor?
So recently I decided to replace the screen on my iPhone 6s plus. While researching parts, I decided also to re-shell the device, placing the internals from the original housing into a new home. The phone worked beautifully (or so I thought) for several hours and continues, even now, to function perfectly for everything (GPS, wifi, screen, battery) aside from bluetooth connectivity to headphones, speakers, my Apple Watch, etc.
The bluetooth signal is so poor (about 3 feet) — that my Series 1 Apple Watch is now essentially useless and my array of bluetooth headphones are also now ornaments only. What in the world is wrong with my bluetooth?
I have already replaced the wifi/bluetooth ribbon antenna (the curvy one) as well as replaced the grounding bracket and the NFC bracket. I am out of ideas for how to fix the issue. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hate to say this but it's probably bad antennas inside the housing which requires replacing it again.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Patrick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 3,640
