跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Problems after screen repair at the mall
My iPhone 7 Plus was replaced due to a cracked screen. I took it to the mall to get it repaired and not long after they fixed it my phone has been going in and out of a black screen. Would you know what it is? I’d like to try and fix it myself.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Maybe it is happening because due to a cheap LCD screen. The second thought is if the frame of phone is bent maybe it damaged the new LCD. I highly recommend you to go back.
这个答案有帮助吗?
得分 0
添加一条评论
Flickering/flaky LCD is a surefire sign of either a low quality display or a shoddy repair.
There are exceptions to every rule, but I’ve never seen good repair work come out of those mall places.
From everything I’ve seen, they use bottom of the barrel parts, and half the time put screws in the wrong place or forget to replace the connector plates. Rather than taking it back to them to have them butcher your phone more, take it to a reputable repair shop that offers a warranty on their work/parts and ask to keep the display assembly from the mall repair, then take the display assembly back to the mall and let them know it is defective and see about getting a refund of any sort. If you are going to attempt to fix it yourself, make sure you are sourcing your LCD from a good vendor who backs their parts with a lifetime warranty.
iPhone 7 Plus is not a great phone to cut your teeth on though, as they can be finicky and there’s a lot of ways to mess up that phone during a repair, so if you haven’t tried your hand at iPhone repairs before, a repair shop might be the safest bet.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rachelgarcia17 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 258
