跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Flashlight suddenly stopped working
I have an I phone 5 64GB (black). When activating the flashlight via the flashlight icon and through camera mode the LED just doesn’t light up. Neither does it work with notifications anymore. It used to work fine and all of a sudden it stopped lighting up when it’s switched on. What would the possibilities be? Is this a common fault?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Had this happen to me a couple of days ago a while after dropping the phone. Reinserting the camera ribbon into its port got it working again. My camera pins may not be in pristine condition as it I think I retrieved it from a water damaged phone. Was your camera ever replaced? Perhaps its pins are also worn.
Maybe you could try slamming the back of the phone a bit to see if it realigns. I doubt it’ll make a difference, especially if your part includes the bracket that is screwed onto the board, but other than that, reinserting it could be all you can do.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
neil.rooplal@gmail.com 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 43
