跳转到主内容
Released in November 2017, the Oppo F5 is the first smartphone to use an 18:9 display instead of 16:9. In spite of having a 6.0-inch screen, the F5's width is similar to the 5.5" display with 16:9. Models CPH1723 and CPH1727.
Low Brightness even when adjust to full brightness
How can i improve the brightness. Its way too low compared to my friend’ s oppo f5
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
5条评论
My mobile oppo a83 this screen low brightnes plz help how full brighte screen light plz help me
完成的
i have oppo f5 how to increase the briteness
完成的
My Oppo A31 display brithness is too low after firmware flash. Pls help me
完成的
My oppo a3s low britness help me
完成的
Kenapa ketika ada warna putih langsung kedap kedip layarnya dan suka lama matinya
完成的
添加一条评论
2个答案
最有帮助的答案
Check if the Battery saving mode is ON or OFF.
If it is on you are limited on level of brightness you can select.
这个答案有帮助吗?
得分 1
1条评论:
it's off. have another solution
完成的
添加一条评论
You Hold the 3 buttons at a time power button , lower volume button and home button and you to restart the mobile
that will help any of the problem of the mobile
Thank You
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
andresasedillo 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 12
总计 3,563
