跳转到主内容
The 2016 version of the Samsung Galaxy A3 budget smartphone (model number: A310F).
59 个问题 查看全部
phone wont charge with screws all the way tightened
hi all
I’m having a wierd problem with my galaxy a5. i dropped my phone from a 3rd floor balcony which landed on grass and soft mud but after i picked it up it still worked but wouldnt charge anymore. after some tinkering i discovered that if i slightly loosen all the screws in the phone it charges but as soon as i tighten the screw its stops charging again
does anyone whats casuing that and how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The only thing I can think of is that the soldering for the charging socket on the daughterboard has gotten loose after drop meaning it would require soldering. But if it’s working just by loosening the screws a bit, you might be able to just leave it like that and use it for now.
You can take it to a phone repair shop to get them to fix it for you, luckily this model does not require prying up the screen to get inside the phone.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Gary 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 67
