跳转到主内容
Only turns on with AC power
I have a 2012 MacBook Air 11”. It had some wine spilled on it a while ago. I took everything out and gently cleaned it with isopropyl alcohol. It worked just fine, but the mouse wouldn't move.
Today, I took out the trackpad and gave it an ultrasonic bath in isopropyl alcohol. Now it won't turn on, except for on AC power (and even then only sometimes).
Is this related to the trackpad, or is it something different?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You’ll need a new trackpad as you ruined yours in the ultrasonic. These devices can’t be cleaned using a ultrasonic as the cleaning fluid (any) will seep into the plates damaging them.
Here’s the needed part: MacBook Air 11" (Mid 2011-Mid 2012) Trackpad
MacBook Air 11" (Mid 2011-Mid 2012) Trackpad图片
产品
$29.99
这个答案有帮助吗?
得分 1
3条评论:
Thanks! Will this also solve the power issue?
完成的
First replace the trackpad to see where things are then.
完成的
Thanks! I replaced the trackpad and trackpad cable. This worked. Looks like something in the SMC reset circuit was messed up.
完成的
添加一条评论
添加你的答案
Buddy Guy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 58
