跳转到主内容
第五代iPad,2017年3月发布。可在Wi-Fi和LTE中使用32和128 GB存储。具有9.7“视网膜显示器和64位A9处理器”。
174 个问题 查看全部
Confirmation of Ipad screen replacement
Good day,
I am trying to buy the screen for my Ipad Model 1822 on Amazon, but the screens that I am seeing has reviews saying that the screen did not fit their ipad 5. Can you please confirm if the screen would fit or send me a link for the Ipad 5 Digitizer not the LCD, just the digitizer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Most of those screens should fit, I believe the iPad Air, 2017, and 2018 iPads all share the same digitizer, the only difference being the home button. If you are not sure about the quality of the parts, iFixit carries replacement digitizers in their online store which will work just fine, and are higher quality than what you will find with Amazon/eBay.
这个答案有帮助吗?
得分 1
1条评论:
You can even use the iPad Air 1 digitizers on the iPad 5th gen (2017, A1822) the usual weak spot for the adhesive is the bottom right of the screen where the digitizer ribbon cables are.
To stop it from pushing up using b7000 liquid glue at that spot is required.
Once glue is added it needs to set which takes about 24 hours for full strength, you can use scotch tape to keep the glass pushed down at that spot for the mean time to let it set.
完成的
添加一条评论
添加你的答案
MICHAEL JABARI NELSON 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 141
