跳转到主内容
Portable wireless speaker with a built in microphone. Released January 27th, 2014.
36 个问题 查看全部
Batería de 5 cables
Hey! How are you?
I want to know why this battery has 2 black cables, 2 red cables and 1 white, because i wanted to put another kind of battery that only has 1 black cable and 1 red cable
Hey! Cómo están?
Quiero saber por qué esta batería tiene 2 cables negros, 2 rojos y 1 blanco, porque le quería poner otra batería que tiene sólo 1 cable negro y 1 rojo
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
my guess would be the 2 red are positive the 2 black are negative and the white is possibly data, possibly 1 red and 1 black are charge lines
这个答案有帮助吗?
得分 1
2条评论:
Man, i didn't ask that, i asked why has 2, i know black is negative, red is positive.
So, why has two cable positive and two cable negative
I thank you for the cable white, i didn t know that.
For some reason has two cable red and two red,
Is it that has two different voltage?
完成的
as i previously said it could be to do with charging
完成的
添加一条评论
添加你的答案
Severino Alcantara 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 542
