跳转到主内容
加入维修社区 - 创建账户
于2015年十月26日上市的第四代Surface Pro平板电脑。
Can Pro4's Samsung screen being replaced by LG's?
Unfortunately, I also suffered LCD screen failure of Surface Pro4 like the most of people. I don’t know how to called this issue but I believe you know.
Now I’ve purchased a brand new LCD pannel from Chinese Taobao to replace its original pannel Samsung LTY123YL01-005 (AIDA64 shows -001 though). I’ve learned from forums and websites that Samsung’s screen for Pro4 has flaws and Microsoft switch it to Pro5’s LG LP123WQ1 at the last batch. So I also purchased LG’s.
The seller told me that connector cable also needs to be replaced because Samsung’s is not compatible. After a few days I received my new scrren and connector. But after installation I can see nothing showing on the new screen, it was totally black including the backlight.
I’m confused. Is that old Surface Pro4 model incompatible with new LG screen? The new connector can connect scrren to mainboard correctly and OS boots normally but I can’t get any image.
Another thing is I discovered this new connector’s solder joint having some problems. AIDA64 cannot find new pannel’s name(viewed from Microsoft RD) and I doubt that the seller sending me a bad connector.
Now I’ve bought a new connector from another seller and it’s on the way. But I still holding the question. Can Surface Pro4’s Samsung screen being replaced by LG’s directly? Did anybody also completed the same replacement?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
2条评论
I have just removed an LG screen from the Pro 4.
So if I change the LCD flex for the Samsung screen will it work ok?
Or am I best to use the LG screen for the Pro 5?
The Pro 5 screen is more expensive than the Samsung Pro 4 screen.
完成的
Hey bro, how will I know if it is Samsung or LG is needed for the screen? where to look for identification? I already have 2 screens but it doesnt work. I might have different flex or screen place. thank you.
完成的
添加一条评论
3个答案
已选择的解决方案
Ordered one more cable from another supplier and the screen works great!
Finally, it was cable's problem.
NOTE: AIDA64 was unable to detect LG screen’s data and shows “Surface Display [NoDB]“ under displayer page. Unsure it was the screen or driver’s issue.
这个答案有帮助吗?
得分 3
3条评论:
Can you post the link to your LG display supplier and the correct cable? I would also like to replace my original Samsung LCD which is experiencing Screen Shake.
完成的
Can you post a link for the Display replacement and the Cable?
完成的
I Had my Surface Pro 4's LCD Screen with a Pro5 Screen too. But the touchscreen function doesn't work. What did you do?
完成的
添加一条评论
Where can you get the lg screen from and the cable?
这个答案有帮助吗?
得分 0
添加一条评论
To put an LG display on a version 1.0 Surface Pro 4, you need cable number 'M1010537-093".
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Huang Junjie 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 84
总计 9,586
