跳转到主内容
MBPro starts but screen dead
Hi!
When I press the start button on my MBPro I hear fans, DVD, HDD rev up and power led behaves as it should, but that's it. I hear no startup chime and the screen doesn't activate at all. I have tried SMC reset, I have tried to start it with power adapter only (adapter is working, I use it on my other MB) and I have checked that the RAM is mounted correctly. I removed the hard drive and connected it to my other MB and it works correctly, so luckily I can do a back up of it. Do any of you have any suggestions what I could try next?
Sincerely
/Fredrik
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Try Hooking it up to an external display. See if you get anything. If not then reset the Pram, when its starting up press ( option-command-p-r) Until you hear two beeps. If that still doesn't work try removing one stick of ram it could be corrupt (but highly unlikely).
这个答案有帮助吗?
得分 0
2条评论:
I'll give it a try. Thanks!
完成的
No luck :-( External display doesn't react at all, PRAM reset did nothing and I tried with a couple of other RAM sticks that I know are working.
完成的
添加一条评论
添加你的答案
Fredrik Lundin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 756
