headlight its no power
Hi my honda civi 2006 headlight its no power hiw to check the problems
Hi @sherwinlaja ,
Which headlight, left, right or both?
If one headlight:
left headlight - check fuses #13 (high beam) & #17 (low beam) in interior fuse box.
right headlight - check fuses #12 (high beam) & #16 (low beam) in interior fuse box.
If the fuses check out OK use a Voltmeter to see if there is power getting to the headlight in case it is a faulty headlight connector or bulb etc.
If both headlights:
check fuse #4 in engine bay fuse box. If this fuse is blown, it should also affect the power windows as well.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 80
总计 3,158
2条评论
What if they good and still not working?
由 German Manuel 完成的
@germanmanuel
What is the year of the vehicle?
Which headlight is not working, left or right or both?
Do the tail lights/parking lights work OK?
A bit more detail about what the problem is will help
由 jayeff 完成的
