跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone 7 camera not working! What's wrong?
Hello, I have an iPhone 7 with a non functioning rear camera. I bought this phone second hand. All I know about the device is that it has had a screen replacement before. The device takes video no problem but continues to show a white screen when ever taking a photo. I have looked at the schematics of the iPhone 7 and narrowed it down to one of the filters above the connector (J4501). I saw that the last filter (C2512) has been broken in the microscope (possibly by a screw driver or prying tool). Can this filter be the reason that I am only seeing white in the camera while the video is working fine? I have never done a soldering job that small before, please let me know if I have concluded correctly.
P.S. I've already tried replacing the camera with a known good so the camera module itself being the issue is most likely out of the question.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It appears that you have already diagnosed the problem and answered your own question for the most part here. This break would definitely contribute to any abnormalities with the camera. If you feel comfortable with trying to solder it then go for it but just be forewarned that these types of things don't usually end well.
=( Hope this helps.
这个答案有帮助吗?
得分 3
2条评论:
The thing is, I have never soldered something that small and with such little room to work with. I don't even think my soldering iron can even get inside there. I've never done a soldering job with such a space constriction as those filers above the connector. Is there some sort of professional service that can do this soldering job for me?
完成的
As for repair, look locally for a reputable shop that does micro-soldering repairs. Ideally, you want to find someone local but good workmanship trumps locality. There are many shops worldwide that do this so you shouldn't have any problems finding them. Talk to them and ask how they do their work. Focus on good practices like proper cleaning of boards once completed etc.
If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum.
完成的
添加一条评论
添加你的答案
Dennis De la mara 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 108
