跳转到主内容
This PC is a Dell Inspiron 3000 Series laptop with an AMD processor and a non-touch display. It's model number is 3541.
20 个问题 查看全部
Laptop will not power on
I have a Dell Inspiron 3451 with touch screen and 1T of memory. Used it and it was running fine. Closed it for the night. Next day went to use it and got nothing. Push power button I get nothing. Hold power button down, can here it starting up then screen flashes on for a second then goes off. Plug it in and charing light does come on then after a while starts blinking. Please help!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @tngraham1979 ,
Try the following:
Ensure the laptop is turned off.
Switch off and disconnect the charger from the laptop.
Remove the battery from the laptop. (Here’s a link that shows how to do this).
Press and hold the laptop’s Power button for 30 seconds and then release.
Connect the charger to the laptop and switch it on, then turn on the laptop. (Leave the battery out at this stage).
If the laptop starts OK, allow it to boot all the way to the Windows desktop, let the HDD activity settle down a bit, then shutdown the laptop in the normal way.
When the laptop has completely turned off, switch off and disconnect the charger.
Reinsert the battery.
Connect the charger and switch it on, then turn on the laptop.
If the laptop starts OK, allow it to boot all the way to the Windows desktop, let the HDD activity settle down a bit, then check the battery charge status.
If it is charging, allow it to fully charge before switching off the charger and disconnecting it from the laptop.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tia Hebert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 100
