跳转到主内容
Amazon's second generation e-reader with a 6'' e-ink display, five-way controller, and QWERTY keyboard.
25 个问题 查看全部
My Kindle is charged, but will not turn "on"?
My Kindle is charged, but it will not turn on. It suddenly stopped working. The green light illuminating the On switch doesn't come on and the Kindle doesn't respond which I slide the On switch.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 111
61条评论
I have a Kindle Fire and it had the same problem, just hold the power button down until the screen comes on again, even if the power button is not lit up green...
完成的
It worked for me! Thanks for the info :)
完成的
It also worked for me also. JK
完成的
It's not working for me at all, hold the button for like a minut and still nothing
完成的
I have a reading kindle from Amazon, and I charged it, but it is stuck on the "needs to be charged" screen. It is charged, but it will not turn on. Help?
完成的
显示更多的56条评论
添加一条评论
23个答案
已选择的解决方案
Reboot your Kindle. To do so, you'll need to hold the power switch for about 30 seconds, but it will show you when it's time to let go. The screen will say that it's rebooting and display a progress bar, as when you first set it up.
这个答案有帮助吗?
得分 111
99条评论:
thanks a lot it works
完成的
thank you. i actually took mine in and they said there was nothing they could do. came home, saw this, tried it and it worked. you're my hero!!!
完成的
this worked thanks
完成的
It worked for me too! Thank you
完成的
Thanks a tonn, it worked for me as well.
完成的
显示更多的94条评论
添加一条评论
My Kindle (3?) would not turn on after the screen froze and I did a hard shut down. I used a combination of solutions above to fix it. I held the power button for about thirty seconds, getting the flashing green power light about 7 seconds in and then a flicker of the screen about 25 seconds in. The screen remained blank after that and I let the power button go. I then held down the Alt and R keys simultaneously and the Kindle began rebooting. It is now up and running with all of the contents that were there prior to the hiccup.
这个答案有帮助吗?
得分 22
21条评论:
Magic fix! Thank you! I thought my Kindle was a goner.
完成的
Alt and R worked. Thanks
完成的
Alt and
R worked. Thank you.
完成的
You are a genius! Thank you so much. It worked & I was sure I was going to have to make a purchase!!
完成的
Still getting red line in battery and that's all. It won't do anything. I've tried everything on here.
完成的
显示更多的16条评论
添加一条评论
If holding the switch for an extended time does not work, take a deep breath and resist the urge to fling your Kindle against the wall. Then find a safe place where the unit will not be touched and leave it for 3-4 days. You may need to wait for as much as a week. Once the battery has lost some or all of its charge, try plugging it in to recharge again. No promises, but when my screen froze this worked. The idea came from my daughter, who has similar issues with her iPod from time to time.
Good luck!
这个答案有帮助吗?
得分 9
20条评论:
i was having trouble thanks i did what u said its working thanks
完成的
My kindle wouldn't respond, so I left it overnight. It still didn't respond, I dropped it on the carpet, then it started rebooting ! Just needed a bit of a shock to bring it back to life ! Good luck
完成的
Holding the button down worked for me too
完成的
my kindle isnt working it wont turn on and before when i turned it on i couldnt read it everything was faded away mine is the oldest model.
完成的
We're on holidays and my husbands kindle wouldn't turn on. Found this site. Thanks Kerry Porter my husband tried your dropping trick. It worked!!!
完成的
显示更多的15条评论
添加一条评论
Hi my "kindle 3" was with the same problem.
Problem:
after normally battery charge it does not start any more, no video, no led green. Switching on the green led blinking 2 times before go off automatically.
Solution:
holding sw "on/off" for aprox. 20 secs the kindle start normally.
Many thanks,
这个答案有帮助吗?
得分 3
1条评论:
Thank you so much, the 30 seconds worked . Was on the way to buying a new one.
完成的
添加一条评论
SOLUTION for power button not working,
Take apart your Kindle by watching this video (or another one if you have different model): https://www.youtube.com/watch?v=IpdMFIs0...
Clean and brush thoroughly metal components around and behind the power button, as well as related parts on the motherboard. Put it back together.
If this doesn't help, you can just turn off your screensaver, so you won't need your power button:
Get out of sleep mode by removing your battery, or by connecting your Kindle to computer by USB cable.
On Kindle 3, go to the home screen, press Del Sym, type ";debugon" and press enter. You will now be in debug mode.
Again, press Del Sym and then type "~disableScreensaver". You now have disabled screensaver. To enable it again, you will need to press Del Sym and then type "~resumeScreensaver". To get out of debug mode, type ";debugoff".
NOTE: you do not enter the quotation marks!
On Kindle Touch, just enter "~ds" in a search box, you don't have to get into debug mode. You are disabling screensaver and sleep mode by doing this, your power button will stop working as well. To enable it, restart your Kindle by using Menu. I don't know the command.
P.S. Note that disabling sleep mode will cause more battery drain.
I hope it helps.
这个答案有帮助吗?
得分 3
1条评论:
YES. My Touch now works without first plugging into a computer.
完成的
添加一条评论
I just had this problem too with my Kindle 3 (keyboard).
I forgot to close the window yesterday, and it got cold and the air was slightly damp while charging, so I thought I had completely broken it. I don't think anyone here mentioned that kind of condition in which it happened, but I thought I would - maybe it is a factor of why it happens and nobody thought about it.
Anyway, I had a standby-screen and holding down the power didn't do anything, and neither did anything else I did. So eventually, about to give up I actually found a solution mentioned nowhere else.
I just typed "reset" into the keyboard and hit OK - and it started to reboot!
(not the new-line button, but the one in the middle of the arrow keys)
I admit I didn't think it would work, it was just frustration which made me do it, but it worked :)
这个答案有帮助吗?
得分 2
1条评论:
Are you serious? This is the thing that worked for me?? I thought you were trolling my man! Thanks so much!!!
完成的
添加一条评论
这个答案有帮助吗?
得分 2
添加一条评论
Screen also stopped working after plugging in the charger one day. Didn't know anything about this issue at the time, so I made the mistake of letting it fully charge in this state. I ended up having to let the Kindle discharge on its own and taking a whole 2 months to do so. I kept holding down the power button maybe 4 times to make sure it was totally discharged. After I made sure no power was present I plugged in the charger then the battery charging indicator came on. After 10-15 minutes the Kendle powered up fully functioning. Thanks to all that suggested this!!
这个答案有帮助吗?
得分 2
添加一条评论
Tried umpteen of these solutions for hours.
Eventually logged into amazon and trouble shooted Kindle e-readers - it found my device, (Kindle keyboard - if you are unsure, look on the back of your device at the bottom and find the model number - google it and it will tell you - however, when I logged into my amazon account it knew which model I had).
So held the power button for 40 seconds (who knew 10 seconds could make such a difference) - initially nothing, so went to next stage and plugged in to power - low and behold it rebooted. Took less than 5 minutes to solve the problem I had spent hours trying to sort.
Moral of the story - why google when you can trouble shoot at the manufacturers website.
这个答案有帮助吗?
得分 2
添加一条评论
Thanks so much everyone for this. My Kindle has been irritating me for some time (it is almost 4 years old) - slow to respond, sometimes refused to search when I wanted to buy something, then this morning it froze altogether and I truly thought it had had it! Consulted this forum and proceeded according to advice of others. Held down the on/off switch for well over 30 seconds, then it turned off, waited quite a while without touching it, then the screensaver tree and reader appeared, with a progress bar beneath. This almost reached the end, then stopped, but I told myself patience was everything and in due course it put itself through several processes of internal digestion and eventually restored itself to apparently prime condition. I can now access my list of books, search for new purchases, "turn" pages swiftly, and have just downloaded a freebie classic which appeared speedily on my home page. So just be patient - presumably like all computers Kindles get themselves in a twist every so often and need a re-boot. Hope this helps others.
这个答案有帮助吗?
得分 2
添加一条评论
Thanks everyone!
I tried all of your solutions, (typing reset and pressing the “enter” button, the alt and R buttons, holding down the slider for many seconds, etc…), and it looked like nothing was helping. It drained the battery, however, which was fully charged to begin with. When I plugged it in to start charging , it rebooted , and now it works!
I don’t know exactly what helped, but something did.
So whoever is reading this - don’t give up, even if it looks like the end… (This could actually be a lesson for life. Lol).
这个答案有帮助吗?
得分 2
添加一条评论
although my Kindle is charged, it seems not to turn on when I slide the on switch to the right.
Suggest you slide and HOLD the switch to the right for 15 or 20 seconds. You should get a green light which may turn on then off during that 20-30 seconds. Mine starts to work normally after that and the screen starts up with "Mark Twain's" image or others.
Hope that helps. Al
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem with my Kindle 3 (alias Kindle keyboard) and I had tried to hold the power switch button for 20 to 30 seconds but it did not work! Bummer!
It sounded like I have to power-cycle the device. I guess I have to open it up, test the power-switch, then power-cycle the device if the switch is good.
There is a guide that shows how you can open up this kindle on this site.
这个答案有帮助吗?
得分 1
1条评论:
held my on/off switch for 30secs....yipee it's working again....thank you.
完成的
添加一条评论
There's a good guide on how to fix this here: http://techzwn.com/2011/04/kindle-wont-s...
这个答案有帮助吗?
得分 1
添加一条评论
I have gone through all of the solutions above with my Kindle model D00901. Resetting with the button and draining the battery did not work, but guess what did. Hold down the "Alt" button and the "R" simultaneously for a few seconds. Instant reboot with all files reloaded properly. Thanks so much for that little tip as I was about to go bonkers. This item is essential for my education.
这个答案有帮助吗?
得分 1
1条评论:
Jim where is this alt and r button? I have kindle paperwhite and there are no buttons?
完成的
添加一条评论
Wife dropped it on the carpet. Wouldn't start after recharging. I held the on/ off button down for the 20 - 30 seconds and it did restart. It has to reboot but just leave
alone for a minute or two.
这个答案有帮助吗?
得分 1
添加一条评论
Try resetting the Kindle.
Tutorial is here: http://www.wikihow.com/Reset-a-Kindle
That works for me. Good Luck.
这个答案有帮助吗?
得分 1
1条评论:
I thought mine was unrepairable, did this and its back working again thank you. xoxo
完成的
添加一条评论
My kindle is not charge but i have kept it for charging for last ten minutes but still when i press it , it's the same orange light . Is there any solution for this
这个答案有帮助吗?
得分 1
1条评论:
I have a new model D01100. I’ve charged it but no light and won’t turn on. Any suggestions?
完成的
添加一条评论
I simply struck the back, bottom edge against a wooden surface 4 - 6 times vigorously and the Kindle (5th) unfroze. I tried hard resetting. No joy. It was the last resort. Carry out at your own risk. I believe the problem was caused by accidentally leaving the unit atop a speaker.
这个答案有帮助吗?
得分 1
1条评论:
Thankyou for your help
完成的
添加一条评论
that has happened to me and the light wont even turn on when i slide and release and it is frozen on a screen saver of anna christine with a whole bunch of black and white shapes covering part of it up.
one way to fix it is to hold the alt shift and the r key at the same time for 3 sec
another way is to open it and take out the battery
the last way is to charge it again or hold the button for 30 seconds even with no light
im so sorry about you kindle and i hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
I later found the true solution to the fault: the connection to external and internal power buttons. I disassembled and applied a small amount of strong epoxy resin to the extrusion on the underside of the external power button. The device has encountered no issues for some months now. Disassembly demonstrations are available on YouTube.
这个答案有帮助吗?
得分 0
添加一条评论
Hi I'm trying to purchase a book and my kindle don't want to turn the page. When I'm reading it turns fine . What can I do please. Thank u in advance.
这个答案有帮助吗?
得分 0
添加一条评论
Check out this article. Maybe it will help you
https://utechway.com/kindle-wont-turn-on...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shirley 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 148
过去 30 天: 707
总计 484,253
