跳转到主内容
Replacing broken screen with a titanium screen.
Hi there!
Does anybody know if I could replace the lcd screen of a 15" G4 Powerbook 1.67 GHz with one out of a 15" titanium powerbook?
Many thanks
Sascha
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Scoot Head, if you check these two links you'll find a reference for the Titanium LCD: AU Optics Corporation - PN B152W01 (works in all Titanium models). Looking at the other link, the same B152W01 is advertised for the PowerBook aluminum.
http://home.comcast.net/~macdan/tibook_d...
http://www.powerbookmedic.com/Aluminum-P...
I would be not surprised that you could swap the LCDs (of the same resolution) between the two series minus the 1.67 high resolution PB G4. I often swapped iBook G4 LCDs with iBook G3 ones
.To Sascha: if you want to know your LCD model:
- open Terminal application
- paste this line:
ioreg -lw0 | grep IODisplayEDID | sed "/[^<]*</s///" | xxd -p -r | strings -6
-hit the RETURN key
Once you have the information, search on Google to find if you can get a match with a model of Aluminum PB LCD. Good luck !!
这个答案有帮助吗?
得分 2
2条评论:
Hi lemeris
Following your instructions, I get the same result on both machines: LTN152W3
Does that mean they are definitely compatible?
Thanks
Sascha
完成的
The two panels have the same model number ? So yes it should be compatible.
完成的
添加一条评论
最有帮助的答案
They are different parts so no, you would not be able to use the Titanium LCD for the Aluminum PowerBook.
这个答案有帮助吗?
得分 2
1条评论:
Thought so, thanks for your answer!
完成的
添加一条评论
Why is it I feel like a Pakled when I go to sites like this?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
redfordbertl 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 1,470
