跳转到主内容
加入维修社区 - 创建账户
APS-C微单在2014年2月发布。Alpha 6000可拍摄高达24.3MP的照片,1080p60的影片。 也被称为索尼α6000。
Why won't my SD card go all the way down?
My SD slot on my Sony A6000 will not go all the way down. It only will go about half way down in the SD slot. There is nothing in the slot that I can see. I read where a part of the SD card may have fallen in the slot but I can't see that. Can you tell me how to repair this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
There is a lock switch on the side of an SD card it prevents it from going all the way in.
If that is not the problem you might be also putting it in the wrong way. Hope this helps. Best of Luck!!!!
这个答案有帮助吗?
得分 0
1条评论:
I have one 16 GB card that looks exactly like this but has two tiny tabs on the top which gets it to lock into place. Any other sd card will not lock into place and I can't find any card that hast them. I am using a Sony A3000 which I have two of. I don't have this problem with the other camera. Any sandisk sd card locks in and stays in place.
完成的
添加一条评论
添加你的答案
crglidewell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 31
总计 3,410
