跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
iPhone 6S+ stuck at Apple logo after battery replace (needs restore).
I have a friend who's iPhone 6S+ phone had an aftermarket battery in it that's been working fine for well over a year and some change. Recently the battery started expanding. They kept using their phone, despite the expanding battery. The battery expanded to the point that it was pushing against the glass, which created a gap between the frame of the phone and the bezel of the screen assembly. The phone was used up until the point that the battery would no longer charge and the phone would no longer turn on. After replacing the battery on the phone with an original Apple battery, the phone remains at the Apple logo and won’t boot past that. I've seen on more than one occasion where a bad battery can cause a device to have to be factory reset, but it’s rare. Does anyone know why this might have happened? Regardless, I’m pretty sure the phone will have to be factory reset, but I’m trying to see if there are any other options to get the phone working before doing a factory reset. I also have reason to believe that the gap created between the screen, could have caused moisture to enter the phone.
Also… for the longest time, I’ve been trying to find PC program that’s capable of backing up a device in DFU mode, and haven’t found yet. Is it even possible to back up a device in DFU mode? I’m assuming this is not possible, because that means anyone could take any Apple device and enter it into DFU mode in an effort to retrieve/steal data from the phone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
I spent some hours researching this issue and came across this video after trying to update the phone via restore mode and received an error 26. Turns out that this video explains the issue very well.
https://www.youtube.com/watch?v=WUmY6TVS...
The video is very lengthy, but @12:30, the lady explains that using an iPhone with a bad battery; up until the point that the phone will no longer take charge, will cause data corruption. This is why the phone would not power on complete and was stuck in a boot loop. It was only up until I did a complete factory reset (last resort for me), that the phone restored and worked.
这个答案有帮助吗?
得分 0
1条评论:
How did you complete factory reset the phone
完成的
添加一条评论
最有帮助的答案
I wonder if the bad battery didn't cause an issue with the charge/power circuit. If you want to avoid restoring the device, then probing the main power circuitry (PMIC/TIGRIS/TRISTAR) would be a must. This gets into board level repair and troubleshooting so you may want to consider having this looked at by an experienced tech.
这个答案有帮助吗?
得分 1
添加一条评论
If there's no physical damage (Minho is spot on there) one thing to try would be to get an Apple branded cord and block, and let this thing sit on it overnight. I know it sounds odd, but I've seen that 'revive' dead phones that had been fully charged down before and in various states of bizarre behavior because of it
这个答案有帮助吗?
得分 0
1条评论:
Other than the battery pressing against the screen, I didn’t see any physical damage or leaking from the battery. Will give your solution a try tonight.
完成的
添加一条评论
I changed my batter in my phone and it's stuck on the apple logo how can I fix it with out a computer ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
uBreakIt iRepairIt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 13
总计 2,933
