跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Why doesn't my iPhone 3G turn on?
I fixed the front digitizer screen that was cracked and it worked fine for two days but then..my i phone just blanked out while i was putting protective case on..i tried resetting ti and plugging it into the computer, but nothing, help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
yeah, my mistake, it didnt work.
完成的
添加一条评论
1个答案
已选择的解决方案
Is there a chance that when you were putting the case on, the ribbon #1 popped off and before you got to plug it into the computer, its battery had discharged? If so, try leaving it in the charger for an hour and then see if the computer recognizes it.
这个答案有帮助吗?
得分 0
5条评论:
the thing is, phone was working fine after i put the screen on, you're saying it might have popped off randomly after two days?
完成的
I agree with John hopefully only "the ribbon #1 popped off". To check connect connect your iPhone back to computer with iTunes open does iTunes recognize it? When connected to computer does your vibrate switch make phone vibrate? If yes to either, then most likely ribbon #1 is loose.
完成的
unfortunately, when i connect it to the computer the i tunes doesn't recognize it, neither does my computer and the apple logo doesn't even come on, its so weird, it just blanked out, it won't do anything, it doesn't vibrate when i do that either.
完成的
You said you reset the iPhone. But lets try another Hard Reset. Hold both at same time Power and Home Buttons for about 15 seconds until the iPhone powers on. If this does not work then... It is time to carefully open up your iPhone and carefully reconnect Flex Cable #4. Carefully put your iPhone back together. See if that fixes it. Good luck.
完成的
thank you, i'll do that, i dont have the tools with me right now but i'll get hold of them later.
完成的
添加一条评论
添加你的答案
sofia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,977
