跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
PS4 doesn't start blinks blue
Hey everyone,
I have a PS4 which won't start. All that happens is that the blue light turns on and continuously dims and brightens again. No white light appears, and the PS4 doesn't respond to the controller. I've already tried using a different power supply, but no luck there. I'd greatly appreciate any help.
Thanks in advance,
Minas
This is a different PS4 to the one mentioned in my other thread.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
已选择的解决方案
After quite some time searching I’ve come to the conclusion that it is probably a problem with the APU chip. The next step now will be to take a look at reflowing the motherboard, but I highly doubt it will work permenantly.
Anyway, thanks for all the help!
这个答案有帮助吗?
得分 0
1条评论:
What???? How do you do that mine won't power on at all it had the issue of having to reset it by unplugging and replacing the cable and it would work but this time all that happens is the blue light flashes then it becomes unresponsive. No light what so ever. I took the plastic off amd cleaned all the dust but didn't do and good think it could be the power supply?
完成的
添加一条评论
最有帮助的答案
there are a few things it could be the the apu chip, ram or southbridge chip. but theres no way to test which 1 it is
这个答案有帮助吗?
得分 1
添加一条评论
go on Xbox should fix the issue.
这个答案有帮助吗?
得分 1
添加一条评论
here's a link i found that may help further diagnose it. I hope it helps.
https://www.usgamer.net
这个答案有帮助吗?
得分 0
4条评论:
Since I've tried with different TV's, Power Supplies and Hard drives, I can guess it's only an internal issue. :/
完成的
I will check and see if I can find a solution other than contacting Sony.
完成的
Any luck yet?
完成的
I apologize, I think you are correct in your determination of the APU chip. It requires microsoldering and could be difficult to repair. I wouldn't use the heat gun method as this is likely to do more damage than fix the issue.
I would check with Louis Rossman to see if they are able to change this for you.
https://www.rossmanngroup.com/
完成的
添加一条评论
Hi
I had this problem too, it took ages but eventually I found an easy fix!
Follow the linked guide and never have problems with your console again
Your welcome in advance
https://bit.ly/2xJ2kC8
这个答案有帮助吗?
得分 0
1条评论:
I tried this repair and couldn't get my PS4 repaired. Though I did fix my gaming problem.
完成的
添加一条评论
添加你的答案
Minas Mayth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 25,477
