跳转到主内容
Self-priming automatic electric pumps with helical gears, produced by Marco.
How can I setup two pumps on the same system?
I understand it is possible to set up two pumps that work together on the watersystem. I suppose that
  • when one of the pump fails, the other will take over;
  • The combined pumps will give more water pressure
Is that correct?
How should I setup a two-pump system?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Just put 2 pumps in paralell setup. It workshop as you discribed.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gaston 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 127
