跳转到主内容
Smartphone by Huawei, released April 2015. Includes models Y625-U32, Y625-U21, Y625-U51.
20 个问题 查看全部
Desoldered micro usb pads/golden fingers
When i removed the usb port from the board some of the soldering pads were missing.
First i tried to replace them with some pads from dead board but the board was so eaten i didn't had any copper to solder them.
So with a very thin sand paper i scratched the surface then i could see the copper.
I've seen that people make bridges with copper wires and solder them slightly up from where usually the legs of the usb port land. But where do i need to put the wires, is there another layer on the pcb? Because i don't see any trace paths.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Perhaps if you were to post a close-up photo of the damaged section of board we might be able to help.
完成的
use some flux and a thread of copper from any wire and run it from the exposed metal lead to where the pad was. Using heat rather than a solder iron past this point would be helplful so you dont undo your work once you get the jump wire where you want it. hope this helps
完成的
添加一条评论
1个答案
最有帮助的答案
you have to find schematics and do a jumper from the trace which you have broken.
you can prevent this from happening by using flux and a higher temperature to remove the charging port.
check on google images for huawei y625 charging ways. you can find diagrams of which traces you need to do bridge a connection from.
这个答案有帮助吗?
得分 1
1条评论:
Yes i did it with hot air, but there were only two pads left already when i removed the port. And yes your advice is right, i found some pictures of the board with doodled bridges of where i could solder
the wires.
完成的
添加一条评论
添加你的答案
Angewolf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 141
