跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Phone won't turn on
I got a phone from a friend who needed help replacing the screen after dropping it and breaking it.
First thing before even buying a new screen I wanted to see if the phone is still working so I plugged it in my computer, itunes installed, but my computer can't see it at all.
(No device recognition sound or anything on the computer screen, itunes can't see it)
How can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
The phone seems to be charging fine though, I can feel the heat when it is plugged in. normal heat.
完成的
How long have you left it charging for?
It could be that the battery is flat for the time being and needs more time for it to charge up enough to turn on.
3Utools application from 3u.com may help you with detecting whether the iPhone has booted properly with the cracked screen.
It does sound like the LCD display on the screen has also gone bad not just glass resulting in no image on the screen.
完成的
That was it, After charging it for about half hour it showed sign of life. I thought apple mobile device can power on without a battery. (as long a cable is plugged)
完成的
添加一条评论
2个答案
已选择的解决方案
After charging it for about half hour it showed sign of life. Weird I thought it could power on without a battery.
这个答案有帮助吗?
得分 0
添加一条评论
Press and hold the two buttons at the same time
这个答案有帮助吗?
得分 0
1条评论:
That's the first thing that I've tried. (Home and Power)
完成的
添加一条评论
添加你的答案
Roje Ha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 158
