跳转到主内容
加入维修社区 - 创建账户
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
Phone won't charge unless I force it in a certain spot
Recently, I have found that in order for my phone to charge, I have to directly force the cable inside, or to a certain angle for it to charge, which most of the time doesn't last long. I'm not too sure whether or not there's a fault at the charging port, as I have tried 2 different cables, and the problem still persists.
I have tried looking at other posts, which don't directly answer my question as there is no dust/lint to be found clogged inside.
Please let me know if there is something I can do to fix this, otherwise I'll pay a visit to my local store to sought the problem. (I'm guessing it has to do with my charging port)
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Hi @xyzzy ,
The USB port may have come loose from the daughterboard and is not making a good connection.
Here’s a link to the ifixit 三星盖乐世S5 Micro-USB 接口子板替换 guide which shows how to access the charging assembly board so that you can see if this is the case.
If it is loose then as it is an SMD (surface mounted device) type component, you’ll need SMD soldering tools and expertise to reconnect the connector onto the board.
You could also simply replace the charger assembly - (select Charger boards link left side of page - example only to give an idea of the cost of part) or search online for Samsung Galaxy S5 (insert your particular model number) USB daughterboard assembly part for suppliers that may suit you better.
If you find this too daunting, contact a reputable, professional mobile phone repair service and ask for a quote to repair the port.
Alternatively if you have no need to access the phone via the USB port, you could opt for Qi wireless charging the phone. Again search for suitable suppliers for this part.
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
添加一条评论
@jayeff suggested procedure is very nice. but i also suggest to check your mobile with other charger adapter. and try to clean charging port of your mobile with cotton and clean it. It this not work then go for the above procedure
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
xyzzy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 2,495
