跳转到主内容
加入维修社区 - 创建账户
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
MacBook won't boot, charger has green light, battery not charging.
I have an old MBP 2009 3.06Ghz which I've used as a backup device for a while. The last time I lent it out to a roommate for a few weeks and I got it back and it was still working. I let it sit in my closet for a while and after 2 months tried to boot it up again but nothing. Charger gives a green light so that means the SMC is getting juice. Battery is not charging however and the charging LED won't turn amber.
I've currently been able to make it work by bypassing the SMC, but that won't charge the battery either and won't make it recognized. I've looked at the DC in and it seems like there might have been some liquid there and I have a white spot on my screen which wasn't there before, meaning that there has been liquid on the LCD backlight sheet.
However, I don't think it's water damaged, all the other components look ok.
The battery was at 98% wear before it stopped being recognized all together. I've already tried disconnecting and reconnecting it but it doesn't work. Resetting the SMC also doesn't work, only an SMC bypass. Everything else seems to be working however when bypassing the SMC. Searching online hasn't yielded me any results.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Ok, seems like the issue has been fixed. I left the charger attached and went on an errand run for 45 minutes and when I came back the battery was charging again. Everything seems to be working now without issues, SMC is reporting fanspeed values, temperature and battery percentage. No idea what went wrong but it seems fixed now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Drinky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 84
