跳转到主内容
A gaming headset that is compatible with the Xbox One.
How to fix water in microphone
So I was playing Xbox with my friends and just as I was talking to them I decided to drink some Pepsi, just then I started choking and spluttered some Pepsi inside the mic and it just got worse from there. What should I do?
It got inside the little tiny hole and when I’m talking to my friends on Xbox they can’t hear me at all
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
5条评论
I have a elecder i39 and i got water in the little hole and it wont work at all. I have to use the chat for zoom.My mic is attched to the cord and its really annoying.HELP ME PLS!
完成的
i cant get the mic replaced bc it is part of the cord
完成的
same i thought a mic would survive coke then it started to buzz alot with a voice changer
完成的
MY Mick sound problem
完成的
MY Mick sound problem please solve
完成的
添加一条评论
3个答案
最有帮助的答案
try letting mic dry i suggest air dry or blowing into the hole it help me
这个答案有帮助吗?
得分 3
添加一条评论
Hi,
Your best option is to replace the microphone boom as most probably the microphone will be damaged beyond repair, even if you could get to it to repair it without damaging it.
这个答案有帮助吗?
得分 1
2条评论:
What if the mic is attatched to the headset?
完成的
mine is and you would have to cut the cord
完成的
添加一条评论
you can try to hairdry it or blow it out that might help
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ruairi.moran 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 48
总计 25,812
