跳转到主内容
Repair and disassembly guides for microphones.
37 个问题 查看全部
I just bought a used sterling mic st51 its fading in the sound pickup
i was wondering if this mic can be fixed it seems its fading in and out i dont know if the cardiod is destroyed or i need a direct box to give it more power ido have 48v on the mixer im using i just would like to see if it would be worth getting fixed or not
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Kenneth, the ST51 may no longer be in your possession, but if it's gathering dust somewhere, rather than try to repair what is really an entry level mic, a couple of options: (1) buy a new (old stock, because the mic no longer in production) ST51 for about $100 if you can find one, or (2) think about using the body to build an entirely new, far superior audiophile mic.
For the latter option parts would run about $200 for pro audio grade components and transformer, and $175 for a primo K47-style cardioid condenser capsule. You would end up with the audio equivalent of a Neumann U-47 FET, a $4,400 mic (new). You do need to be handy with a soldering iron or have someone with the knowledge and skill to do the work (too complicated for beginners).
If neither is an option and you just want to get rid of it, a DIYer would be interested in buying it just to use the body to build a completely new mic.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kenneth stout 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 32
