跳转到主内容
Released at 2013, September. Display size - 480 x 800 pixels, 4.3 inches. Internal memory - 4 GB, 1 GB RAM. CPU - Quad-core 1.2 GHz Cortex-A5, GPU - Adreno 203
Why does my HTC phone only boot when its plugged in.
Hello, So I an HTC Desire 500 series, everything works fine with the device other than the fact that it will be stuck in a continuous boot loop unless plugged into a power source. The minute I disconnect it, it resumes boot looping. I am not familiar with android phones and mostly only work on iPhones. Please help. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
If it works OK with the charger connected but not when on battery power only, then most probably the battery is failing and needs to be replaced.
Here’s a video that shows how to access the battery.
Battery suppliers are available online. Just search for HTC Desire 500 battery to get results.
这个答案有帮助吗?
得分 2
2条评论:
Thank You, do you know by any chance where I can source a good battery. I very seldom work on Android devices so I don't know who to contact for parts. Thanks!
完成的
Hi,
Just search online as suggested and then select the one that suits you best. You could always select the one that states genuine OEM battery.
完成的
添加一条评论
添加你的答案
Dennis De la mara 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 208
