跳转到主内容
加入维修社区 - 创建账户
Why won't turn on? (Power cable at mother board)
My computer was experiencing kernel panics very often, so I disassembled it. There was no dust. When I assembled it, it didn't turn on. Caps Lock lamp lights, so there is a working power source. Maybe it's because of power button? Connector is connected to socked, but...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If it's right that you're dealing with a 12" PB, doublecheck the powerbutton cable on the left side of the computer. Is it plugged in properly. You might want to check it with an ohmmeter to see if the button is switching.
这个答案有帮助吗?
得分 3
3条评论:
I checked over 9000 times, if it's the red-black pair. Ohmmeter? Ok, will check. P.S. Could the button be broken during disassembling?
完成的
Rather unlikely but still possible - just check it.
完成的
Well, the trouble was in RAM case. When I screwed screws there, it didn't work. When I unscrewed it, it work.
完成的
添加一条评论
添加你的答案
AFakeman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 983
