跳转到主内容
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 个问题 查看全部
How do I fix my controller stuck on G on keyboard?
So basically I got this pre owned controller and when I go to type it glitches and stays on the G button, no matter what I do. I tested out the controller in-game and again, it spams certain inputs. I have bought a cheap wired controller and it appears that the problem was the touchpad AND the L3 and R3 buttons. So my question is how do I fix this and is there an option rather than purchasing a controller. Also is there a way to plug a headphone jack into the PS4 if there is no way to fix.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
Repairing the controller in this case sounds impractical. I would just buy a new controller.
There is a reset button on the back of the PS4 controller you could try.
There is no way to connect headphones to a PS4 directly, only through the controller.
这个答案有帮助吗?
得分 1
1条评论:
you can absolutely plug a mic and headphone in the usb plug of your ps4 and a adapter that you plug them in , thats i plug my headset with my mic
完成的
添加一条评论
i think you have to get your controller fixed or try to fix it your self and you would have to open the whole controller
这个答案有帮助吗?
得分 0
添加一条评论
Restarting the PS4 usually fixes this issue, as rebooting any device fixes most issues. Do note that the bug will reappear after a while. I have this same exact issue with a controller I brought a month ago and restarting the device is the cheap way to do it. If that doesn’t work, reset the PS4 controller, which is a small button underneath the L2 button. You might need a paperclip or a mechanical pencil to press this button.
这个答案有帮助吗?
得分 0
添加一条评论
I did all of this and none of it worked. I tried forgetting and reconnecting the controller restating the game and updating it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josef Baydemir 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 128
总计 11,703
