跳转到主内容
加入维修社区 - 创建账户
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
MacBook Pro won't turn on with power button on keyboard
I inherited an early 2013 Macbook Pro 15" that wasn't starting up. MagSafe lights up, but no power. Tried disconnecting and re-connecting the battery. No change. Tried disconnecting the battery holding power button down to fully drain the power. Once I reconnect the battery, as soon as the MagSafe adapter is connected, the laptop starts up and functions perfectly, aside from the power button functioning. If I shut down the laptop, I can't power it back on with the power button. I need to disconnect the battery, hold power, reconnect the battery and attach the MagSafe, then it powers back up again on it's own.
The power button must be physically working as I have to press it to fully drain the board, before plugging it back in, and I have already wiped and re-installed the OS with all updates, and I've reset the NVRAM. I tried doing the SMC reset, but the power button doesn't appear to function during that.
Obviously this sounds like a board issue, but is there anyway to manually flash the firmware on one of these, or anything else I can try to do to resolve this? Laptop seems to work fine otherwise.
EDIT: Just realized it's actually a Late 2013 model not the early 2013 one I originally posted
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I don't see this as a firmware issue so thats not going to help.
完成的
添加一条评论
2个答案
Lets do this locate the power pads as marked here
With the system assembled carefully short across these two pads did your system start?
这个答案有帮助吗?
得分 0
2条评论:
When you say to "short across the pads", do you mean, take a wire and touch each end to areas you have marked?
完成的
I use a pair of tweezers or a screwdriver blade. It doesn't take a long hit 1/2 a sec is all thats needed.
完成的
添加一条评论
So I screwed up on my original post, it's a Late 2013 not Early one. Anyway, here's what I'm seeing on my board, I assume the connection points must be different? I tried jumping a wire between those points but nothing happened. Am I supposed to have the power adapter plugged in as well while doing this?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 143
