跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 个问题 查看全部
Could dead keyboard be the reason for A1534 MacBook 12 not turning on?
I'm considering purchasing a liquid damaged Macbook.
Judging by the pictures and seller description the logic board doesn't seem to be affected by the spill. Is it possible that the logic board itself is fine, but the power button on keyboard does not work?
I want to make it my first laptop I get back working myself. I've watched tutorials on how to replace the keyboard and I think I can follow them, but troubleshooting the logic board might be too much for me right now.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Hi,
It could be the keyboard but I would not take the risk. If the is broken it is very hard to find the broken part and replace it with microsoldering. I would wait until I find a MacBook that you are sure you can fix.
But if you think it is the keyboard buy it to a fair price.
完成的
Thank you for suggestion. I think I will give it a shot and buy the broken Macbook.
When it arrives I will let you know if keyboard replacement worked and what was wrong with it.
完成的
添加一条评论
1个答案
已选择的解决方案
It can be a keyboard may be fault is with keyboard, but i suggest you to go through a regular diagnosis which will help you to find the possible issue to fix your device.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Gabriel Malinowski 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 704
