跳转到主内容
Device and repair information for the Behringer Eurolive B212D speaker system.
31 个问题 查看全部
Speaker sound fades in and out.
The sound frequently cuts to only the tweeter playing music very softly. If I hit the back component plate that houses the volume knobs, power plug-in, input/output, etc. it seems to sound normal again. Anyone know why?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
could be the amp module going bad or the connection to the driver
这个答案有帮助吗?
得分 1
添加一条评论
From your description, I would expect to find a poor solder connection on the amp itself. If you can solder, remove the amp plate from the back and look at the connections. If any of the solder connections appear to have rings, resolder them
Let us know if you find anything and whether or not the resoldering resolves the problem.
Dan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tzs5183 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 364
