跳转到主内容
加入维修社区 - 创建账户
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
How can I improve the battery charge rate while using navionics?
iPad battery loses charge while operating navionics navigation program, even though it is constantly plugged in to charge on a 12 volt system. Need to improve rate of battery charge somehow.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Connect your iPad to a Mac system and run on the Mac CoconutBattery it will tell you the health of your iPad’s battery. Lets see what you find out.
You also maybe hitting a limit here with this iPad series running this type of program.
Have looked at getting a newer model? The older APU’s pulled more power and given your use the APU is stripping the power faster than the battery (or charger) can offer it. You could try using an external battery pack but I’m not sure that will offer enough juice if your direct power feed is unable to offer enough current either.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Liz Crawford 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 13
总计 168
