跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Can I reuse the battery adhesive strips from here?
I'm replacing the battery from an iphone 6 with a new one from here and I'm also using the adhesive strips from here. I don't know if anything else is wrong with it besides the battery. If there is, and I have to remove the strips again, would I be able to take them off and use the strips again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The battery adhesive strips are for one-time use only. When you replace the battery, install the battery but without the strips, check everything to make sure it works and then install the battery strips and close the device.
这个答案有帮助吗?
得分 2
添加一条评论
There is no way to remove the strips without destroying them once you've installed them.
As @refectio said, do a test run without the strips and then install when you're ready for final assembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ernesto 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 297
