跳转到主内容
加入维修社区 - 创建账户
新 Nintendo 3DS 是 3DS 产品线中第一款大幅更新的迭代设备。在日本于2014年10月发布,北美市场于2015年9月发布。2015款 3DS 改进 3D 显示性能,全新 C 摇杆,内置 amiibo 读写功能,以及全新的4肩键配置。
How to fix power problem?
Hello, this is the first time I've come to this site but I've found it useful already but I still need help.
I've just tried playing my 3ds and it just keep popping and turning back off after a couple seconds. I think I may have jostled something in the hardware but I don't know. I do a lot of traveling and have it on me in my backpack all the time so may be I have shaken something loose.
I would just like to know how to remove the casing and what to check to see if I can repair this problem.
Step by step instructions would be appreciated.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
1. Have you checked the charger? Make sure the contacts on the side that slides into the DS aren't bent or broken. If this is an issue just replace the charger.
2. You may also need to replace the battery if the battery is not holding a charge.
And if those two things do not solve the issue:
3. It's fairly common over a period of time for the charging port inside the DS to become worn out. Get a flashlight and take a look at the charging port to see if anything looks bent or broken. If this is the issue you would need to bring it to one of those cell phone repair shops (I would call beforehand to make sure they work on handheld gaming systems) otherwise you might have to buy all the soldering equipment and parts and do the soldering job yourself.
Good Luck!
这个答案有帮助吗?
得分 0
1条评论:
The charge cable is fine. The charge port is fine. As a bit of extra information, it spends a lot of time in my bag and it may get jumbled around a lot.
Could something have come loose from the board?
Also the lower screen is the one that flashes when the system pops and turns back off.
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 202
