跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Why won't my iPhone 3G turn on?
A few weeks back, my iPhone 3G went dead out of the blue. Ever since, I have been trying to switch on my iPhone and the system doesn't start.
I have plugged in the power to recharge the battery, synced it with iTunes, but it doesn't start at all.
I would appreciate any suggestions/solutions pertaining to this problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
3条评论
I've had this iPhone for 2weeks and just today it just went dead when it was hundred percent battery it just turned off I tried to hold the top boton and it still did not work
完成的
IPhone 3g does not full turn on but when I connect to pc then only apple show then after turn off.. We have again the Home button is not working but no power ..
完成的
My iPhone 3G starts up but turns straight back off I don't understand why do u AV any idea please
完成的
添加一条评论
14个答案
已选择的解决方案
It sounds like a dead logic board. Have you tried rebooting the iPhone by holding down the sleep/wake button and home button simultaneously?
这个答案有帮助吗?
得分 15
10条评论:
I have tried rebooting my iPhone by holding down the sleep/wake button and home button but it hasn't worked so far. It tries to reboot but then gets hanged.
完成的
Im having the same problem with mine. If u found what fixed urs let me know please.
完成的
Hi max it would probably be better if you ask your own question.Click on the link on the right side of this page "Ask a Question" and give as much information as possible. Right now it looks like you are answering an old questions. Good Luck
完成的
my iphone 3gs has just turned off and does not want to turn back on. hmmmm maybe its the battery its not charging the phone
完成的
I've got the same problem with my 8GB 3G. I've replaced the battery and that hasn't changed anything.
Basically, if I plug in a connector cable that is connected to a USB I get a silver Apple logo appear on screen for a minute or so, then the display disappears apart from a very faint Apple logo (almost like screen burn) until I unplug the cable, then it disappears completely.
If I try and put it into DFU mode, it comes up with the Connect to iTunes graphic. I connect to iTunes, iTunes recognizes a device is in DFU mode. I try and restore but it fails instantly with an Error 23. It then disconnects itself.
Does this sound like this an economical thing to try and fix, seeing as I can get a 2nd hand 16GB for £250?
完成的
显示更多的5条评论
添加一条评论
IPHONE Model: MC676LL RAM: 14GB (10.4 Avail)
CODE Ver: 4.2.6 (8E200)
PROB: Symptom: My Iphone went dead at work.
1)I tried plugging into the car charger thinking the battery was dead, but no charge and no charge indication = still dead.
2) I tried my home charger, (thinking it was the car charger) but I got the same symptom = still dead, nothing nada...
ACTION: I checked you tube and found this site
FIX:
1) I checked this site and came across the suggestion above to "by holding down the sleep/wake button and home button simultaneously" and it worked. I entered the security code and all is in order.
这个答案有帮助吗?
得分 4
2条评论:
I had the same issue when I did plug it into a dock station. Apple offered a free replacement in store (Genuis)
完成的
I will try to get a replacement in Apple store in Bangkok next week.
完成的
添加一条评论
just hold power and home button ata a tym..........ur phone will restart with in 2 mins :)
这个答案有帮助吗?
得分 3
3条评论:
Thanks brother,u saved me today..it worked fine..Thanks again...
完成的
Thanks you save me :)
完成的
thnaks a lot :) i thought i can't open my phone anymore :)
完成的
添加一条评论
Hold the power and the home batten for 10sec then release your hand on the power batten but still keep your hand on the home batten for about 4sec, release ur hand now, your iTunes should detect it now.
这个答案有帮助吗?
得分 0
2条评论:
holding sleep and wake wont always work because my iphone is used and the top button is broke and works rarely s i could do it nonstop for a week and it might not wrk or it could do it 10 times straight I NEED HELP!!!
完成的
Thank u vry much it worked
完成的
添加一条评论
I had a similar problem, and mine turned out to be a loose connection from when I replaced the LCD. Once it was properly connected I had no problem turning it on.
这个答案有帮助吗?
得分 0
1条评论:
thanks so much JM9K i had the same problem
完成的
添加一条评论
Totally bizarre guys. I GOT IT WORKING!!
Had the exact same issues as everyone else.
Thought it must be the battery. Changed it.
Tried to power on get the apple logo then disappears.
Tried holding power and navigation button screen blinks then nothing.
Tried this several times. Then it occurred to me.
Hold the power button on the apple logo comes up keep holding it till the apple logo goes away. WAIT for a few more seconds...
Now WHILST holding the power button STILL press and hold the navigation button and keep holding it.
It will then showup the apple logo again keep holding it....
The screen goes blank (it does not blink)
Then the connect to itunes screen comes up and its business as usual restore method.
Hope this helps people.
这个答案有帮助吗?
得分 0
1条评论:
now what i do?
完成的
添加一条评论
Bizarre:
I tryed to turn on the iphone, tryed to recharge and nothing happens.
I seens that the my iphone 3g was dead.
Then I tried the following instructions and it worked:
" Hold the power and the home batten for 10sec then release your hand on the power batten but still keep your hand on the home batten for about 4sec, release ur hand now, your iTunes should detect it now. "
Now it´s working. :)
这个答案有帮助吗?
得分 0
添加一条评论
just hold down your home and wake/sleep button at the same time for about 20/10 sec trust me it works I just did it......
这个答案有帮助吗?
得分 0
1条评论:
thankkkkkk alot dont know how
happy i am
完成的
添加一条评论
i have exactly the same problem. i just had my battery changed. everything was working perfectly when all of a sudden it died but i still have 18%. i tried to turn it on but it doesn't go beyond the apple logo, i tried to plug in i was thinking that the battery drained but still got no solution. i tried everything already! help!
这个答案有帮助吗?
得分 0
添加一条评论
Try to restart it by entering recovery mode. Recover mode is a failsafe for iOS so it may fix your problem. The best and easiest way to enter or exit recovery mode for iOS device is to use the free program ReiBoot, now it is famous across the web. Have a try if needed.
这个答案有帮助吗?
得分 0
添加一条评论
i think i know your problem press and hold power buttonand home button untill it vibrates keep holding untill options come up hope this works
这个答案有帮助吗?
得分 0
添加一条评论
Hi Guys sorry this isn't about turning off but i realy need help!!!!!!!!!!!!!
My dad turned off my 3G so i can press on on the iphone but it still won't work. How can I change it so it will work?!!
这个答案有帮助吗?
得分 0
添加一条评论
I had the exact same problem and the problam was the wall plug, the wire AND the charging port being dusty. I cleaned the charging port, changed wires and wall plug and its working.
这个答案有帮助吗?
得分 0
添加一条评论
my iphone 3g randomly shut off and it keeps saying "connect to itunes" and when i do that it says it disconnected from dfu mode but when i look back at it it still says the same thing. i tried to reinstall the os with reiboot and nothing worked please help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paribesh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 47
总计 135,497
