跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Y000 screws too tight to remove
Trying to replace the screen on my iPhone 8. I’m at the part where you have to remove the large metal shield/backing plate attached to the back of the screen. This needs to be removed and put on the new screen assembly. It also needs to be removed to get access to the home button.
I’ve managed to remove three of the Y000 screws securing it. But none of the others even look like loosening. They’re too tight. It could potentially be the cheap driver I am using. It’s just one of the ones that comes with replacement screen. But I had no issue with the first three screws. So I’m not sure that’s the reason.
I’m worried that even if I spend the money on a decent driver, it still won’t help if the screws are too tight.
I’ve even considered worse case scenario of buying a new home button and backing shield. But I can’t find the backing shield for sale ANYWHERE.
Anyone have any advice. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Hi Todd
I have also had the same problem where I'm not able to screw some screws out because they´re to stuck or the screw is stripped.
There is not to much to do about it than, in your case, to buy a new LCD Shield Plate for your iPhone 8.
Only the original home button will work on your phone because it has the haptic feedback home button that is linked to only the iPhone it came with, so do not replace it with some other home button.
Anyway, my suggestion is just to force the LCD shield plate out in some way for you to be able to remove the original home button.
I found an iPhone 8 LCD Shield Plate on this website, and would assume that this isn't the only place where they sell these. (https://www.fixez.com/iphone-8-lcd-shiel...)
Hope this helps
这个答案有帮助吗?
得分 1
1条评论:
Thanks heaps Daniel. I’ll give your suggestions a try. I’m going to try a better quality screwdriver. Then if that fails, I’ll look at buying parts. I appreciate your help.
完成的
添加一条评论
I've had some success with using JB weld on screws and attaching an old driver to it. It usually gives me enough torque to remove the screw. Just make sure you apply the JB weld only on the screw.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem, I didn’t want to pay for an for an other screwdriver set so I just betn the home button bracket carefully so I could take it out, to then bend it back once in the new screen and screw it tight… and tadaa… worked like a charm.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Todd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 2,594
