跳转到主内容
Model A1138 / 1440x960 screen resolution
85 个问题 查看全部
问题已关闭
Sometimes won't boot only startsound, doesn' charge
Sometimes won't boot only plays the start-sound. The screen remains black and nothing else will happen. The front LED is permanently glowing. The PB also won't charge the empty battery. The DC-cable indicator is always green.
In some cases the book will start up, but after about 30 minutes it shuts down. No massage, nothing.
Thanks for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
To rule them out I'd try a different AC adapter (make sure it's 65-watt, because 45-watt won't work with your machine) and a different battery, and I'd try to reset the PMU (hold down the power button for ten seconds while power is off and machine is connected to AC).
Beyond that, since these issues are all power-related, there's a good chance the problem is with the DC-in/sound board. I've generally found that flaky power issues are resolved by replacing this part:
[关联产品丢失或禁用: IF154-108]
这个答案有帮助吗?
得分 3
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,011
