跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Is this SSD compatible and do I need an adapter?
I just ordered the following SSD for my early 2013 MBP Retina 15". I've read some say it's compatible, some said I need an adapter and some said it's compatible but then need to download drivers. Is anyone able to assist?
Samsung 960 EVO Series - 500GB NVMe - M.2 Internal SSD (MZ-V6E500BW)
https://www.amazon.com/gp/product/B01M20...
I was told this adapter is what I would need.
https://www.amazon.com/Adapter-MacBook-R...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Lets start off on the SSD’s connector, The Samsung 960 EVO is a NVMe M.2 drive. Your Mac uses a custom physical SSD interface so these will not mate directly!
The drive dialog of your Samsung SSD is PCIe/NVMe but your MacBook Pro is expecting mSATA III (6.0 Gb/s) interface drive. So this drive will not work in your system even with the adapter you’ve linked to.
To help clarify things, review this diagram:
Your system uses the Purple path on the left. Here is a great reference on what Apple used for SSD’s The Ultimate Guide to Apple’s Proprietary SSDs And your system uses the second generation of SSD’s (GEN2) within this guide.
If you can, I would cancel the order and look at just getting the correct SSD to start with from BeetsTech (or any other good source like OWC or Transcend) in the long haul its just gets you a better outcome.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Christopher C Stone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 215
