跳转到主内容
联想笔记本电脑的维修和支持指南。
2562 个问题 查看全部
error pci lan realtek pxe bo3 d00
Hi everyone! I have a problem with my laptop. Since today it freezes out of nowhere and i have to shut it Down only from the Button. When I turn it on again i get this message
“ pci lan realtek pxe bo3 d00”
What do I need to do? I Did the test on my harddrive and Its 100% and i also got into BIOS where lan is enabled; realtek is on the last position and the HDD is on 1st position .
It takes a lot to turn on Windows aswell.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
A mí Lenovo le puse un disco sólido y no me deja instalarle el Windows 10. Me salta el mismo error.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @am1nutza
Is the boot order set correctly?
What is your model of your laptop?
How do you test your hard disk? using lenovo diagnostic - F10 ?
the PXE boot is normally activated when the computer is not able to boot to windows.
I would suggest you to check on the hard disk again and perhaps all hardware test, is there any error?
else there could be a possibility either the OS is corrupted or unstable HDD.
这个答案有帮助吗?
得分 3
5条评论:
Thank you ?
完成的
what I do if these problem happen?
完成的
hi i have lenovo x131e laptop it is coming code pci lan: realtek pxe b03 d00
完成的
What i do if these problem happen
完成的
What do I need to do? My laptop model is Lenovo V110_15AST. What should I do.
完成的
添加一条评论
添加你的答案
Anamaria 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 133
总计 12,353
