跳转到主内容
Repair guides and support for a wide range of welding machines.
15 个问题 查看全部
Plasma cutting depth and thickness
I'm trying to open a old safe I found in a building that my company was raring down and its older safe over 350 pounds I've got a plasma cutter 60 amp it says it cuts 1 inch steel as so manybinch a hour
My question is that and will a plasma cutter cut deeper and deeper but it will make the cut slower and very ugly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have heard of some older safes containing materials that you don’t want to mess with if you are a novice. I would consult with my local locksmith who I know to be an expert on older safes. Can’t answer your questions regarding plasma cutting equipment however. Movies tend to make stuff look much easier than it in fact is.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
stephen kealey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 116
